Lincoln Forums: 95 Towncar ABS & Airbag Warning - Lincoln Forums
Jump to content
andys auto sport
Help Us Help You | Lincoln Store | Lincoln Shop / Service Manuals
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
95 Towncar ABS & Airbag Warning Trouble codes are flahing on my dash Rate Topic: -----
#1 User is offline   hojoe
  • New member
  • Pip
  • Group: Registered Member
Posted 06 March 2005 - 11:17 PM
I Have a 95 lincoln towncar the ABS & a Airbag code 52 are flashing and it really annoying, I readed an article that explained for me to ground a pin on the airbag data connector but i cant happen to find the darn plug , can any one please help will greatly appreciate
#2 User is offline   95ltc
  • Lincoln fanatic
  • PipPipPip
  • Group: Registered Member +
  • Car I drive:95 lincoln towncar
  • How did you find out about us?:lincolnvscadillac
Posted 08 December 2005 - 10:45 PM
On my 95 the air bag light came on and kept blinking, but then i unplugged the batt. for a little while and never happened again.
#3 User is offline   TEXIANJOE
  • Lincoln fanatic
  • PipPipPip
  • View gallery
  • Car I drive:1997 MARK VIII LSC
  • How did you find out about us?:GOOGLE SEARCH
Posted 09 December 2005 - 04:39 PM
Code 52: Intermitent or repair of lost battery feed. The manual diagnosic chart refers you back to code 12 battery feed lost.
At one time the battery was removed and replaced. Or the fuse in the power distribution box position K has been blown and repalced causing less than 8v to go to the module.
It could also mean that this vehicle at one time was in an accident and the internal fuse in the Restraint
Control Module has been blown the codes cleared and then they returned. The internal fuse is not servicable the RCM needs to be repalced.
How long did you drive the vehicle before the light started flashing.
If you disconnect the battery for about 15 minuits it may erase the code. If it comes back after that it need to be diagnosed to see what is causing the light to flash.
joe
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Lincoln? Check out your options at the links below:
custom floor mats | lincoln performance mufflers | lincoln performance exhaust systems | racing seats | lincoln euro tail lights | lincoln air intakes | lincoln projector headlights | lincoln ground effects | lincoln body kits, hoods and lambo doors | lincoln body kits | lincoln carbon fiber hoods | air suspension kits | air suspension parts
