Lincoln Forums: keyless entry keypad on door "wigging out" - Lincoln Forums
Jump to content
andys auto sport
Help Us Help You | Lincoln Store | Lincoln Shop / Service Manuals
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
keyless entry keypad on door "wigging out" Rate Topic: -----
#1 User is offline   malibu71
  • New member
  • Pip
  • Group: Registered Member
  • Car I drive:2000 Lincoln Towncar Executive
  • How did you find out about us?:google
Posted 30 October 2009 - 06:24 PM
2000 Lincoln Towncar Executive. The keypad on the driver's side door will not unlock the doors or trunk. I AM using the correct code from the trunk sticker (it used to work just fine). The interior lights do come on when I try to key the code. When I hold the last two buttons on the pad it OCCASIONALLY locks the doors. This all started last winter during a very cold snap. The car's battery died at the time. The battery is new now. I am not sure if there is a way to reset the system. I know there is a procedure to reset the code to a personal one, however the factory code will not work. At the same time, the auto door locking feature failed (the one that locks the doors when you start moving). I was able to fix this by toggling this feature OFF then ON as described in the owners manual. Is there something similar for the keypad? Thanks for any help.
Supporting Members do not see this advertisement nor many of the others. Please click here support our community.
#2 User is offline   RJPhoto
  • New member
  • Pip
  • Car I drive:2000 Lincoln Town Car
  • How did you find out about us?:Yahoo Search
Posted 01 November 2009 - 07:23 PM
You said that you hold the last 2 buttons and it will lock the doors.
What else can the Keypad be programed to do besides unlock the doors and pop the trunk?
#3 User is offline   malibu71
  • New member
  • Pip
Posted 01 November 2009 - 07:58 PM
Uh, that pretty much sums it up. I don't really understand what you're asking....
#4 User is offline   RJPhoto
  • New member
  • Pip
Posted 01 November 2009 - 09:11 PM
On my '97 Taurus (no keypad) I can turn the key 2 times and open all of the locks.
On my Lincoln, the keypad only unlocks the driver side door. Passengers have to wait until the the locks are unlocked from the inside.
I was hoping there was an extra button punch like you used to open the trunk that would unlock all of the doors.
#5 User is offline   hmeister
  • Lincoln enthusiast
  • PipPip
  • Group: Registered Member +
  • Gender:Male
  • Car I drive:1997 Lincoln Continental
Posted 01 November 2009 - 10:44 PM
Here is a snippet I found on another forum: - You can try the 3/4 button after you unlock and see if it works - (see below)
I have a 1992 Lincoln Town Car and it's located on the passenger side trunk hinge. It looks like someone wrote it on a piece of paper and taped it there.
If want to change the code because of not knowing it, there is a label inside of the trunk lid "usually" on the hinge arm of the trunk *passenger side*. but in order to change it to some other series of numbers, you'd have to take the car the a Lincoln dealer and pay out the wahoo for anything that they do. Last I heard it was close to $80 an hour for them to do anything :( Anyway hope this helped...
Answer - I found the following buried in a cdrom "factory service manual" for '93-94 Towncar, crown victoria, & marquis, so far, many things have turned out to be interchangeable between the crownvic and towncar that i have been patching up for the last few years. anyway, hope it helps, here is the data.
To program a temporary code, enter permanent code sequence. Within five seconds of pressing last button of permanent code, press the 1/2 button. Enter any alternate five digit code within five seconds of pressing 1/2 button. _______________________________ To unlock the driver door, enter the permanent factory code or the owner's alternate code. This will also disarm the Anti-theft system, if equipped. _____________________________ To unlock the passenger door(s), press the 3/4 button within five seconds of unlocking the driver door or luggage compartment.
To unlock the luggage compartment, press the 5/6 button within five seconds of unlocking driver or passenger door(s).
To turn on the interior lamps, lift either front door handle or press any button on the keypad. All illuminated components will light.
To lock all doors, press the 7/8 and 9/0 buttons at the same time. It is not necessary to enter the key code first. This will turn off courtesy lamps and arm Anti-theft system, if equipped.
to the earlier post, yes its on the trunk hinge for '93 too even tho the factory users guide state that it is on the "deck"
to find in on the control module, you have to pull the glove box out, and remove the module,(mounted on the kick panel with 2 nuts on studs, and 3 wiring plugs) the label is hidden on the backside with the part number
There should also be information in the owner's manual as how to change the code. Otherwise, the information above is also true of a 92 Crown Victoria.
#6 User is offline   RJPhoto
  • New member
  • Pip
Posted 02 November 2009 - 12:13 AM
IT WORKED.
Thank you so very much.
That has been bothering me since I bought the car.
#7 User is offline   hmeister
  • PipPip
  • Gender:Male
Posted 02 November 2009 - 06:26 AM
View PostRJPhoto, on 02 November 2009 - 12:13 AM, said:
IT WORKED.
Yeah, it worked on my 1997 Continental also. After I found the snippet, I went outside and confirmed this works...
Crusing the junk yards, I have found the code is also sometimes in the user manual on a factory sticker.
When I first found this sticker with the numbers, I did not know what the number was for.
Most Ford/Mercury/Lincoln have this factory number on the right trunk hinge.
I removed my sticker and put the sticker into the user manual in the glove box.
Regards;
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
0 members, 1 guests, 0 anonymous users
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Lincoln? Check out your options at the links below:
custom floor mats | lincoln performance mufflers | lincoln performance exhaust systems | racing seats | lincoln euro tail lights | lincoln air intakes | lincoln projector headlights | lincoln ground effects | lincoln body kits, hoods and lambo doors | lincoln body kits | lincoln carbon fiber hoods | air suspension kits | air suspension parts
