Lincoln Forums: 2004 LS running but no acceleration? - Lincoln Forums
Jump to content
andys auto sport
Help Us Help You | Lincoln Store | Lincoln Shop / Service Manuals
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
2004 LS running but no acceleration? Rate Topic: -----
#1 User is offline   tgifford5
  • New member
  • Pip
  • Group: Registered Member +
  • Car I drive:2004 Lincoln LS
Posted 07 November 2009 - 08:51 PM
I have an '04 LS V8. On the way to work getting on the interstate and accelerating it al of a sudden went flat. It kept running but no acceleration at all. It would only go about 45 - 50 mph. Tranny was rebuilt this summer and seems to shift alright. But to step on the gas nothing. Anyone have this same issue or what might I check? Is there something I can do to fix it?
#2 User is offline   Right on the Mark
  • Lincoln fanatic
  • PipPipPip
  • Car I drive:MK8 and LS
  • How did you find out about us?:web
Posted 08 November 2009 - 01:53 PM
Your car is in "reduced power mode" oralso called limp home mode. The cars computer noticed something really wrong and sets off the limp home. There must be other warning lights on the dash right? Usually its from overheating.
#3 User is offline   tgifford5
  • New member
  • Pip
Posted 08 November 2009 - 09:45 PM
ETC engine safe mode light on and the check engine soon light also. The engine temp. had been fine. Got it to the service station today. Will let you know what they find out.
#4 User is offline   tgifford5
  • New member
  • Pip
Posted 09 November 2009 - 11:10 AM
Talked to the service station today. And there were 2 codes that came up. One for a new oxygen sensor and the other for the throttle body. I'm adding an oil change while there. But the bill will be around 9 pesos.
#5 User is offline   Right on the Mark
  • Lincoln fanatic
  • PipPipPip
Posted 10 November 2009 - 12:26 PM
Your year has a fly by wire throttle body. Meaning no throttle cable anymore. They do have a problem with those popping up. You have to replace the whole TB unit most of the time. Those are not cheap.
#6 User is offline   tgifford5
  • New member
  • Pip
Posted 11 November 2009 - 09:13 AM
Also on another note. Got the call from the shop. The throttle body is on back order. The release date is not until Dec. 18. Had to get a used one. So if yours goes out you maybe stranded unless your local shop has one in stock. Yea about not being cheap. The new ones run $700ish.
#7 User is offline   Right on the Mark
  • Lincoln fanatic
  • PipPipPip
Posted 11 November 2009 - 08:26 PM
Thats why I like my Gen 1, nice old throttle cable. LOL
#8 User is offline   tgifford5
  • New member
  • Pip
Posted 16 November 2009 - 09:10 PM
They also had to reprogram the computor. And 3 coils had to be replaced, but they were covered under a recall. Runs great! Just thought I'ld let you know what all was done.
#9 User is offline   danielsatur
  • Lincoln enthusiast
  • PipPip
  • Gender:Male
  • Interests:Degree in computer Science, and enjoy working on Auto ECU's, and control modules.
  • Car I drive:Towncar
  • How did you find out about us?:google
Posted 24 December 2009 - 09:54 AM
Caution - A bad throttle body cleaning could damage the calibration on the control module.
A stickey throttle plate, because of PCV gunk will cause lost horse power & random misfires.
Anytime you lose the signal on a drive-by-wire system, the engine will go in Failsafe mode.
Check, and clean the electrical connection going to the Throttle body control module with CRC electrical cleaner. I have seen water roll from the cowl onto the engine, and short the APPS signal out on your CM.
$2k for a 5-min fix!
This post has been edited by danielsatur: 24 December 2009 - 10:20 AM
Share this topic:
Page 1 of 1
1 User(s) are reading this topic
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Lincoln? Check out your options at the links below:
custom floor mats | lincoln performance mufflers | lincoln performance exhaust systems | racing seats | lincoln euro tail lights | lincoln air intakes | lincoln projector headlights | lincoln ground effects | lincoln body kits, hoods and lambo doors | lincoln body kits | lincoln carbon fiber hoods | air suspension kits | air suspension parts
