Jump to content
lincoln suspensions
MLPS
6 replies to this topic
#1 aerigan
  • Registered Member +
  • Pip
  • 22 posts
  • Car I drive:92 lincoln congressional town car
  • How did you find out about us?:internet surfing
Posted 20 February 2012 - 03:37 PM
I need to replace the MLPS on my 94 town car tranny. Anyone have a pic or diagram as to where it is located? Also is it hard to get to or anything like that? Its also called a nuetral safety switch.
#2 LithiumCobalt
    Lincoln fanatic
  • Super Moderator
  • 1,952 posts
  • Gender:Male
  • Interests:Cars, my house, being outdoors, vacationing, construction, accounting
  • Car I drive:Fords & Lincolns
Posted 21 February 2012 - 01:10 PM
Hi aerigan,
The MLPS will be located on the side of the transmission. You are going to need to have the car on a lift, jackstands or ramps in order to have enough room to get underneath and work on it. Do you have a factory service manual? If not, I would suggest getting oen and following the procedure on how to R&R. It's not as simple as just pulling the old one off and putting the new one on. It needs to be positioned correctly. Good luck!
#3 aerigan
  • Pip
  • 22 posts
Posted 21 February 2012 - 02:27 PM
well i bought a new one from oreilleys and installed it this morning. All was good till i road tested and car will not shift into 3rd or OD. Car starts in 1st then shifts to 2nd and thats it. I aligned the nuetral marks on the mlps as stated in the instructions that came with it and made sure car was in nuetral when i removed the part and replaced it too. Im not sure what could be wrong????? The reason i replaced was because car kept shifting into nuetral at highway speeds. Was told by dealership that tranny is fine and only found out about the mlps by this forum and it sounded like the problem.
#4 aerigan
  • Pip
  • 22 posts
Posted 21 February 2012 - 07:30 PM
well after looking at the instructions on installation.....maybe i have to use the new plug and grommet that came with it....i didnt use it and plugged the harness directly into the new safety switch. I saw that in the box was a new red plug and it looks like you have to pull each wire out of old harness plug and route them into this new red one....and they go into different spots??? Anyway its like a 7 pin to an 8 pin or something. The part is a BWD brand and the part number is S9190. Looks like the wires need to go to all new positions for some damn reason. Such as pin 1 on old is blank and on the new one pin 8 will be blank and so on....ugh!
#5 Mike 1993
    Lincoln enthusiast
  • PipPip
  • 59 posts
  • Car I drive:1993 Town Car
  • How did you find out about us?:Internet search
Posted 21 February 2012 - 08:51 PM
Could be that's how BWD is getting around a patent??
#6 LithiumCobalt
    Lincoln fanatic
  • Super Moderator
  • 1,952 posts
  • Gender:Male
Posted 22 February 2012 - 09:27 AM
One reason I buy Ford parts. Might cost you a little more money, but costs you less time and aggravation.
#7 aerigan
  • Pip
  • 22 posts
Posted 22 February 2012 - 11:47 AM
I looked at the motor craft part and it said same thing in instructions and cost 50 bucks more. I put old one back on and all gears right as rain. Hell i dont know what to do now? I looked and the original harness has 6 wires going in and out but the instructions on the motorcraft part and the one i bought both show 7 wires with a blank pin 8. I might just have to live with it going into nuetral every now and then while driving.
1 user(s) are reading this topic
MADISON ROSS MEDIA GROUP MARKETPLACE
Need products for your Lincoln? Check out your options at the links below:
lincoln parts | lincoln body kits | lincoln exhaust systems | lincoln tail lights | lincoln navigator body kits | lincoln wheels
